http://adelaide.gumtree.com.au/c-Cars-Vehicles-Motorbikes-Parts-parts-accessories-engine-engine-parts-transmission-GTS-T-RB20-RB25-Xtreme-Drift-Clutch-Kit-with-aligning-tool-W0QQAdIdZ330166408
New Condition, still sealed in packaging. Please note: Flywheel not included. Alignment tool included.
Below is the information off the website.
Nissan Skyline RB25 Drift Clutch
Brand new Xtreme Motorsport Kit + Flywheel Part number: KNI24501DSBMSCF
To suit Nissan RB20 and RB25 Skyline R32 and R33 push type applications.
Xtreme has just released it's brand new design 254mm clutch for the RB25 engine. This Xtreme setup features a cover with chrome-moly casting, designed for excellent strength and heat durability.
Clamp load on the cover is 1600kg - a massive 130% upgrade from standard!! It runs with the Xtreme Dampened Solid Button (DSB) clutch disc with ceramic facings for high heat dissipation and excellent holding characteristics.
Also included is an Xtreme chrome-moly flywheel which is available in THREE (3) weight configurations: FNI024C Chrome-Moly 5.5kg Excellent upgrade from standard FNI024CL Lightweight Chrome-Moly 4.5kg. Great for track use FNI024CD Drift Chrome-Moly 10kg designed for drift use to keep inertia of flywheel.
The Xtreme kit also comes with spigot bush, pressure plate bolts, thrust bearing carrier and aligning tool for easy install. Keep in mind the Xtreme cover, disc and flywheel are all SFI APPROVED, so you know you're getting true quality.
The Xtreme DSB disc is designed for track / race and drift use.
Part Number - KNI24501DSBMSCF
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
