Funding New Project. Prefer to be contacted by Mobile 0.4.6.8.8.8.7.4.4.0.
20111120200315900x1200360x4801321956239.png20111120200329900x1200360x4801321956239.png20111120200341900x1200360x4801321956239.png20111120200359900x1200360x4801321956239.png
KKR-480 TURBO (Less than 2000k's use,No Shaft Play) - $400
20110626025735480x3601321956421.png20110626025743480x3601321956421.png20110626025753480x3601321956421.png
RB25DET HEAD- Bare head Perfect for head replacement (Cleaned,Decked,prepped,Pressure Tested,Crack Tested,Valves Seated,Stem Seals replaced) - $450
SIEMENS 3145 750CC TOP FEED INJECTORS(Suit RB26) - $400
RB25DET RECO TURBO LSD (Tighter than ya mum fo real) - $400
20111120201717900x1200360x4801321956239.png20111120201732900x1200360x4801321956239.png20111120201747900x1200360x4801321956239.png
GFB DUAL MODE BLOWOFF VALVE (vent to atmosphere and plumback) - $50
CA18 TOMEI CAM GEARS - $200
20111120201825900x1200360x4801321956297.png20111120201843900x1200360x4801321956297.png20111120201855900x1200360x4801321956297.png
38MM EXTERNAL WASTEGATE - $150
MANUAL CONVERSION PEDALS (Accelerator,Brake and Clutch pedals) - $150
Accelerator Cable (Good condition) - $30
20111120203612900x675360x4801321956297.png20111120203625900x675360x4801321956297.png20111120203709900x675360x4801321956297.png
GREDDY EMANAGE ECU (No idea what its for but it came in my car when i got it)(Comes with loom plugs) - $200
RB25DET ACTUATOR - $5
20110903091836480x3601321957034.png20110903091928480x3601321957034.png20110903091935480x3601321957034.png
SR20 GENUINE NISMO SHORT SHIFTER - $100
Does the bov come with flange to fit to the rb25 ?
Yes. Will fit straight up to standard RB25 Blowoff flange. Comes with O-ring already installed.
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
