Will a GTS-4 box fit in a GTS-t to make a baby R33 GTR?
Question is how strong is this box to hold the power from
a turbo engine? Or even better put in a GTR box?
If above can be done: what front diff should be used &
is rear diff needs to be changed to match the ratio?
What about ATESSA then, does it just straight plug in n play?
https://www.sau.com.au/forums/topic/3839-r33-gts-4-box-in-gts-t/
Guest Impul 25T
Originally posted by rs73
Does anyone know the reason why GTS4 doesn't come in turbo version for R33 series? Is it not allowed by the SEVS scheme or is it coz Nissan never made one?
The didn't do it because there wouldn't have been enough of a step to the GTR...... make it harder to sell them. There are kits available for the R34 GTS4 to turbo them, so I would imagine that you would be able to get them for the 33 also........ but in saying that, turbo'ing them can be done, but can be quite expensive if you want to get all the oil feeds and other internal bits right. There is one over here in Wellington, and lets just say he eats almost all of the local GTR's with it.
Turbo'd R33 GTS4
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
