Ok so I have lots of stuff I need to sell, all the r33 parts had 52xxxkm on the clock completely stock
1. R33 gtr RB26dett head completely stock as factory fitted from intake plenum to turbos, injectors, coils, covers the lot $1800
2. R33 gtr gearbox, standard flywheel and transfer shaft (missing shifter) $900
3. R33 gtr all standard Intercooler piping & bovs $200,
4. R33 gtr standard ecu, $250
5. R33 gtr whole front cross member 5 stud hubs (no brakes) $250
6. 2xstandard gtr intercoolers r32 and a r33 both have a few bent fins as usual. $300each
7. R33 gtr brake booster complete with pedal and all $150
8. Rb26 starter motor $150
9. R33 front TEIN coilovers $200
10. R32 vspek2 TEIN coilovers Full set (rear left is a bit knocky) $400
11.EOI R32 rb26 full reco head(like new) , and intake everything complete exc covers and turbo manifolds $1500
everything can be posted at buyers expense
Inbox me your mobile number for any pics
Located Taree nsw 2430
Edited by RB-20-VL
https://www.sau.com.au/forums/topic/387892-gtr-parts-nsw/
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
