Guys,
Girlfriend wants to get rid of the soarer. Serviced regularly by myself using Mobil 1 oils and Valvoline Oil Filters.
Engine is in very good order and the car drives well. ( for a boat :))
Recently had a major service done including replacement of all belts (this is how we know the KMs are a little more than they seem) and the radiator.
Service was performed by BMT (RIP) about 4 months ago.
Price: $17,500 negotiable
Year: 1991
Model: JZZ30
Engine: 1JZ-GTE (2.5litre TTurbo)
ODO: 70,000 (is more likely to be around the 90,000 mark)
Trans: AUTO
PICS: http://aussiewheels.com/profile/View.php?I...&PhotoGallery=1
0-400: 13.8seconds @ 102MPH at calder park.
Contact: 0431 076 366
Email: [email protected]
Aftermarket Parts:
-HKS Pod filter
-3.5" Exhaust from the catback with a Trust style cannon muffler with a 5" tip
-Boost guage (multicoloured back light 7 colours)
-17" x 8.5" front and 17" x 9" Zeitt Rims with 235 SIME tyres all round
-Vertex style Front bar and Side skirts
-Remote alarm and immobiliser
Std Features:
-Power steering
-Air con/Climate Control
-Cruise Control
-Traction Control
-Cloth/Leather inerior
-TEMS Suspension
-Electric windows
-Rear window is only window tinted (came like that :P)
Sound Gear:
-Clarion in Dash TV/CD Changer
-Sony CDXM850MP Head Unit (black flip down face with picture display)
-300w x 4 channel Audioline amp (installed one month ago)
Willing to sell car without the audio equipment for an adjusted price.
https://www.sau.com.au/forums/topic/38842-fs-melb-1991-jzz30-soarer-tt/
no actually it was purchased in a rough state with a cracked front bar, clogged radiator, timing belt on the way out and broken filler cap as well as a sub standard sound system for over 16k
thanks for your welcome input tho...
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
