I have a BIG BOY JVC 15 INCH 1000WATT SUB-WOOFER IN A PORTED BOX.
it is in very good condition and produces very deep body shacking bass.The sub is a high end sub in the JVC range,The box is a professional ported enclosure not some home made box. It has gold plated connections and has thick OFC wiring inside the box.
This box and sub combination responds well to all sorts of music from RNB /Dance to Rock
You are more than welcome to come try before you buy.
Asking $170 for the sub and the box together.
Pick up is from Taylorslakes Melbourne. Call / sms 0422756270 if interested
Edited by G4orce
  • 3 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
