I'm missing floormats from the rear of my 33GTR.
I have the front ones and the rear centre one, but hte ones the rear passengers put thier feet on i am missing
Looking for geninune GTR mats to match the rest of mine...
If I can't find any, i may have to buy a whole set - in which case i will have to sell the mats i don't need, so if anyone wants new front mats or the rear centre one, let me know
https://www.sau.com.au/forums/topic/39101-wtb-rear-floormats-for-33gtr/
so between benjiman Jive and me, we could just buy a set and split the cost?
Anyone know where to get a good (near new or brand new) set from? how much are we looking at?
  • 2 months later...
