In Melbourne.
Nissan L20ET 2 litre 6 cyl SOHC EFI Turbo. Upgraded with RB20DET BB core turbo and dump pipe. Complete with Wolf 3D v3 management system, loom, hand controller. HD clutch. RB20DET intercooler (requires pipework to fit your application), and Malpassi rising-rate fuel pressure regulator. Would suit a R30 Skyline, but can obviously be made to fit anything.
$1000 ono
https://www.sau.com.au/forums/topic/39458-l20et-wolf-3d/
  • 2 years later...
In Melbourne.
$1000 ono
dude, where in melbourne can i find someone that knows what they are doing with one of these motors? I've got one in my R30 and need a new ECU for it... couldn't be bothered working this motor (can't squeeze much out of them) and just need it to run well enough so the fuel pump won't shut off
help me out
[email protected]
https://www.sau.com.au/forums/topic/39458-l20et-wolf-3d/#findComment-2944481
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
    • Have you done 10x restarts since it came on?
