for sale is my series 1 jzx100
mod list
exceedy hyper single plate clutch with lightened fly wheel
cusco coil overs
series 2 tail lights
cusco strut braces
slotted rotors front stock rear rotors with endless brake pads all round
hdi front mount kit
hks super scilent exhaust with high flow front pipe
wheels are 19 inch avs model 7 powder coated white
apexi cold air intake brand new in box
blitz bov is plumb back atm but the adaptor is there to make it vent to atmo all brand new still have the box
car still retains the stock air box with hks pannel filter
i have polished the cam covers /throttle body /water out let/and intercooler outlet the j pipe and inlet manifold is done in black wrinkle coat centre cover is mat black went for a stealth look less cop hastle
the car has had full major service last week done water pump all idlers and tensioner /timing belt/spark plugs /coolant/all oils diff has motul gearbox has redline shock proof engine oil gets done every 6 months or 3000 kms car does not get driven much as i get a company car and the misses drives this to and from work.
spare parts that come with car are all left overs i have from a part out of another 100 i bought there is all 4 doors with most parts still in them there is a spare boot with wing all door class and rear windscreen /2 front seats /a spare series 2 dash with no lift /stock exhaust 3 spare 19 inch tyres spare rear bar that has gay fog lights in it series 1 tail light thats all i can think of atm
$17000 ono
phone 0409454739
https://www.sau.com.au/forums/topic/395527-jzx100/
Free bump for a very tidy, and nicely subtle car: makes me miss my Chaser! thumbsup.gif
What's the mileage?
Is it factory manual or converted?
If converted, does it have the Torsen LSD?
https://www.sau.com.au/forums/topic/395527-jzx100/#findComment-6284548
car has 90 k on it i converted it to manual before x mass has torsen lsd out of manual chaser everything to do with conversion is out of a manual jzx100 pedals box diff tail shaft i went to the extream of putting the manual tunnel in it and manual ecu car retains the original cluster just has the manual black face on it as that is the only difference between the manual and auto cluster everything kept original
if anyone wants to check it out i am more then happy to throw it on a hoist at work and you can have a look
Edited by bernardshorty
https://www.sau.com.au/forums/topic/395527-jzx100/#findComment-6284579
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
