Hi mate,
have i missed the price somewhere? I am geniunely interested but need alot of questions answered.
How did the piston crack look/where? is there actual compression readings across the cylinders?
I have just been quoted ~$2000 to exchange a motor across 3 workshops across sydney. Is the quote to fix the
piston only or include removal and install of the motor?
Will one piston just be replaced for $1300. Who will be doing this? will headgasket be reused? choice of bearings?
Can this person your using rebuild this motor to my spec seeing its going to be apart already?. No point pm'ing as
im pretty sure theres plenty of other people asking the same questions.
Cheers
  • Replies 47
Very valid questions, and your right its very good for everyone to know.
compression across the rest of the motor is outstanding, 170psi, 170, 168, 170, 170 and then cylinder #6 35psi and 50psi on a wet test. first time i did the tests myself i got in the vicinity of 150 but then i noticed my gauge was a little screwed, so i just had it check properly, and then checked again myself with a new gauge to verify the 170psi readings.
The crack is more of a fracture in piston #6, and the rings which were giving the low reading , The valves and cylinder are fine, not bent or anything.
The cause of the problem was a faulty boost crontroller solenoid ( $30 - $50 ), spiking of the boost i was told led to this.
well yes i mean it works out perfectely for anyone looking to do a rebuild anyway or who has a engine ready for a gtr or something similar...
my quote and intentions were to return the car to its normal state with all the mods still ofcourse.
so anyways... basically pull apart the pistons and replace anything surrounding that is needed e.g rings , im not 100% certain what bearings would be used. im pretty sure i would have sourced some decent looking used parts where i could, reason being it was fine handling the power if it wasn't for the boost controller solenoid. i know people may disagree but sometimes money isnt always available when needed.
A close friend quoted to do this for me if i chose to go down the path myself,
i was going to forge the motor if it didn't sell but with certain issues at the this point, im not going to anymore. im going to sell/swap the way it is.
I hope this helps and havn't missed anything. if you want to talk further PM me ill give you my phone number.
alright fair enough, bad luck with the solenoid mate.
check your inbox i sent you some more details, ive got some parts from my previous r33.
let me know also when your free tomorrow
Bump...
Should be gone shortly, haven't been in hurry lately so i apologise to the guys wanting to come out just been very busy.
Always has been a top car to drive, especially down to canberra once a week for a few months straight. receipts for work and dyno papers to come with, always been looked after. really a shame that a small $30 solenoid caused this. A couple of SAU members have had the car checked also and have told me their quotes are pretty much the same as mine, give or take a few hundred.. probably give more so :)
Just have some common sense, if your going to offer me 10k think about it.. your getting a 12k Gtr ...please save your time and dont have sulk when im an asshole back. :)
losing the company vehicle .....
willing to put a few thousands on top for a swap.
otherwise i got no choice but repair and wait close to a month for it to be done through my mechanic.
Edited by binga85
Update
It's in the Workshop now!
Might be getting fixed if i can get it done quicker than 3-4 weeks. otherwise still selling as is.
Inspections may be a little harder now, however PM and we can sort something out possibly over the weekends as during the week will be very hard now.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
