Up for sale is my pride and joy but also my pain and suffering! I bought this car about a year ago off another SAU member pretty much stock with a built engine. As it turned out, I was unhappy with the old engine setup and have gone down the hard road (DON'T EVEN ASK ABOUT THE COST!!) of building an engine to my own liking. I only JUST finished the engine build and not even driven 10,000kms, I have decided to sell it to move onto other things. Had plenty of things I still wanted to do to this car but unfortunately I have grown tired and weary so now I am looking to downgrade.
This car was built and tuned from scratch by JEM (Just Engine Management) who have spent countless hours (and alot of my drug money errr I mean hard earned cash) and even I am disappointed I did not get to finish this project, so the next owner will definitely enjoy a well built car and will grin from ear to ear every time! Will hand over receipts to the new owner just so they have proof of what has been done to the car.
According to the after market cluster, the odometer reading is at 170,XXXkms but the engine itself has seen less than 10,000kms.
I do not have a current shot of the engine bay, but do note that I have removed the twin air flow meters and replaced it with a custom single intake pipe with a single pod. Also, I have replaced the shroud over the radiator fan.
This car does come with a warning: PREPARE LOTS OF TISSUES!!!
Video:
List of extras:
Haltech Platinum Pro ECU - mafless tune
Forged engine (86.5mm pistons, H rods, studs, bolts, big end race bearing, custom ported head, +1 over sized valves)
Greddy oil pump with 1.5mm restrictors
Tomei 1.5mm head gasket
HKS 264/274 10mm lift cams
HKS stage 2 valve springs
Tomei cam gears
Garrett T04Z with 0.7 rear housing running 20psi
Xspurt 1000cc injectors
Precision 46mm external waste gate
ETM custom turbo manifold - steam pipe
Splitfire coil packs
Custom dump pipe
Ballistic high flow cat
Blitz Ti catback exhaust (stainless steel system but with titanium lipped muffler)
Aftermarket 115mm intercooler
Custom triple core radiator
Greddy oil cooler
ORC twin plate clutch
Zeitronix wide band sensor + gauge
HKS EVC-S boost controller
Greddy oil filter relocation kit
Custom oil catch can
Kumho KU31 tyres 275/35/18
Nismo MFD V2
Nismo 320 dash cluster
Clear cam cover
Pretty sure there are other things I have missed out but the main idea is........ I have spent lots haha
Price: $69,000 negotiable.
Contact: Andrew on 0412 773 767
Yeah it WAS the Envy car but I went through the process of getting rid of EVERYTHING Envy ever did to it. There is a story but I'm not going to tell it here.
Long story short, was not happy with the way the car was so I started all over again from scratch.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
