Hey Guys
selling a Set of 4x Nissan R34 25GT Rims 16 inch stockies with rubber 75 to 80% tread left minimal to no gutter rash came off my 2 door R34 GTFOUR
im asking for $400 dollers Firm which is pretty much 100 bucks a rim with tyre :) will not seperate i want to sell the lot
also selling a stock 25 GT exhaust
asking price
$35
located in Moorabin Victoria pickup only please
need to get rid of these as there taking up room at the panel shop i work at
will try and get pics on monday
till then pm if interested
cheers
Bump price drops on the wheels to 200 Dollers common guys grab a bargain need these wheels gone!!!! :yucky: also have RB25DET NEO exhaust Manifold for sale came off a motor with 108xxxks on the clock, 40 bucks! need this stuff gone!
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
