hey guys im looking to sell my 2011 nissan navara d40 st dual cab ute and 2011 formosa tomahawk 620 centre cab
both were bought brand new car is about 3 months old and the boat is about 7 months old and both have little use as im never home
i paid well over $100000 for both
looking to either sell as package or swap both for a gtr
2011 navara d40 dual cab st 4x4
dvd player with bluetooth & reversing camera
tow bar
sports bar
rust protection electronic
auto
only about 2000kms
2011 formosa tomahawk centre cab 620
150hp evinrude etec
full alloy dunbeir trailer
all fishing essentials
loaded with extras to much to list but truely is the perfect boat
for details on the boat msg me or text me
for both looking for $88000 ono
gold coast
0487924497 for pics or more info
Edited by gtahhhh
  • 1 month later...
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
