Hi Guys,
My S15 I have had for almost a year now is for sale as a roller, It has an Rb30/26 Built engine sitting next to it that has made no progress
and my fiancee is admit that I finish it or sell it, So I am going to see if I can recoup what I find fair.
Car needs the following, Engine,Box, Ecu,Rego
Car Is a 2002 Spec S Blue, No finance, No REVS history,18inch D1RS with good tread, Lowered suspension, Some additional suspension Arms underneath
I havent seen it for 6 months so I cant remember exactly what, Has a Cooler on it too, and 3 inch exhaust. 130ks on the clock.
$8500, no swaps thanks.
Will take 7800 if you bring your own wheels.
Car Is located in Riverwood,
Please msg me on here for number for serious enquiries
also selling rb30/26 combo in parts
Edited by gambla
  • 3 weeks later...
Hey mate i'm interested in the roller can you send me a contact number so i can organise to have a look at some pictures or even come and check out the car if you still have it? Thank you.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
