i have for sale a set of 17X8 +35 lenso d1r. wheels are in excellent condition with only one wheel that has a minor less then an inch gutter rash.
the wheels will come with 225/40/17 fronts 235/40/17 rears adount 60% tread all around for $600. for $1200 the wheels will come with brand new federal RSR's 225/40/17 fronts 255/40/17 rears.
https://www.sau.com.au/forums/topic/401874-17-lenso-d1r/
