  • GTR 33 Front Bar Indicator (Genuine) $150
  • GTR 34 M-Spec Turbo pair (Brand New) $1500
  • H1 HID Kit (Brand New) $75
  • GTR 33 Front and Rear Strut Brace (Genuine) $200 for the pair
  • GReady GTR 32 60mm Pillar Meter Panel (Brand New) $120
  • GTR 33 Air Flow Sensor (Pair) $150
  • Recaro Rail for R33 Series (Passager Side) $200
  • Recaro SR 3 (RED) No rails $600
  • Recaro SR 3 Pair (BLUE) No rails $1100
  • HKS Super Power Flow Air Filter (Brand New) $75
  • Brand new Horn $20
I do not have any parts in mind, but I sometimes buy GTR spare parts. It is always a good idea to post pictures rather than people ask for them. That will save you time. Cheers!
