hey guys i have up for sale the following two sets of wheels.
Wheel no1
Weds Kranze Lxz chrome finish.
18x9+22 f
18x10+31 r
wheels comes with tires around 70% tread. wheels are in good condition. no buckle or chunks missing from wheels. wheels do have your usual gutter rash.
Price $2600 ono. happy to send interstate at YOUR cost
wheel no2:
SSR professor ms1. these are EOI atm as im not 100% sure if i want to fit them to my car or not.
wheels are finished in hyperblack chrome.
specs:
19" x 9 offset +11 step lip
19" x 10 offset +11 step lip
wheels are in good condition. cpiple of minor chips here and there. one wheel has a slight rash. nothing deep. will see upon inspection.
dont have any pics of the actual wheel yet. will post up soon.
$3000 ono
thanks
Ash
Hey ash have a mate from JDMST thats keen on the MS1's are these the ones pictured here?
Where u located for trial fit?
http://www.skylinesaustralia.com/forums/topic/403213-nsw-fs-full-set-of-ssr-professor-ms1-hyperblack-chrome/
for sale: full set of SSR Professor MS1
specs:
19" x 9jj offset +11 NR with step lip
19" x 10jj offset +11 SL with step lip
hyper black colour with polished dish
condition of wheels is great with minor chip and mark here and there but nothing major.
there is one rash about 25cm from previous owner on one front wheel but is superficial and can be machined out easily (can arrange for this also), can arrange tyres also if need be.
RRP for these wheels are $900 per wheel before special coat and shipping
pics below are of the actual wheels on the car they were on (not a promo pic)
selling the set cheap for $2300 shipped anywhere in australia
pickup available also
please pm me
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
