so stripping my baby to stock to sell it....
all parts are loctae din vic and i can post all items anywhere in aus if you pay...
my mobile is 0430078630 sms preferred
Genuine bee r's painted silver/grey..... genuine stickers
17x9+22 fronts federal 215/40/17
18x9.5+22 rears federal 215/40/18
2.5k firm
apexi evc fits my 3 inch exhaust.
$200
2way diff not sure on ratio. 5 bolt...r200
$800 or $650 and your stock or welded diff.
r33 gtr s2.purple sticting seats only one little ciggie hole...perfect seats
fit my r32 perfect,
$1200 or can swap for your stock seats plus cash my way
adjustable whiteline sway bars front and back
$300
hicas lock bar..
$50
adjustable cam gears x2, silver for rb's
$250
r32 slotted rotors fronts only
$150
oil cooler setup from fultuer motorsports.bigger cooler from just jap.
relocation and cooler..
$350
led lights rear pair
$200
Blitz gauges x4...oil temp.oil pressure..water temp. boost,
i have not hooked up the water ever.
awesome gauges love them to bits. glow blue at night.
$700 all senders/sensors and wiring included.
  • 5 weeks later...
bump Genuine bee r's painted silver/grey..... genuine stickers
2.5k ono
$200
r33 gtr s2.purple stitching seats only one little ciggie hole...perfect seats
fit my r32 perfect,
$1100 or can swap for your stock seats plus cash my way
$300
hicas lock bar..
$50
$250
$150
$350
$200
  • 3 weeks later...
2.5k firm $2000 or swaps for 17's have to be decent wheels and offsets no stupid rotors, drift teks etc
Bump
Really want the gauges gone..
Also adding genuine gtr boot with genuine gtr boot wing $300 paint is perfect and colour is white.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
