Rb25/30 Long Engine, T67-25G Kando & Tial W/g, Freddy Intake & 80Mm, Power Fc & Nismo750Cc
Will only seperate parts once engine is sold!
RB25/30 Long motor rebuilt november 2011,
Reco head with welded vtc and waterjacket, RB20 inlet cam, 25 exhaust cam, metal head gasket.
Linished std crank, crank collar, N1 oil pump, New acl bearings and moly rings on std RB30E pistons & rods.
1.2mm restrictors, block drilled, lightly honed. New Exedy HHHD clutch, timing belt, idlers and waterpump.
Can see running and fitted to vehicle.
$1650
Kando T67-25G with Tial MVR 44mm wastegate mounted off exhaust housing.
Includes modified stainless top mount manifold, dump and screamer/flanges/flex.
Turbo 4months old & still under warranty.
Fitted to vehicle and only for sale once engine sold!
$1250
Freddy RB25 inlet manifold & 80mm throttle body, modified to clear R32/S13 master cylinder.
Chrome outer and machined face, Tps & 3' intake pipe/hoses included
$450
Apexi powerFC suit rb25
Includes hand controller, Z32 afm & k/n pod filter.
Tuned by Pits - Rb25 with Z32 afm with 80mm throttle,750cc & Gt3037s with .63.
$1000
Nismo 750cc injectors in modified fuel rail with twin feeds.
$600
Splitfire coilpacks suit series1 R33 Rb25.
$350
Greddy GREX oil cooler kit
big cooler, thermostat and filter relocator, New Russell braided hose
$550
R32 40mm Alloy Radiator & 16' electric fan
$220
All parts are currently fitted to my R32 and I drive it everyday to work.
No dyno sheets, No tyre kickers & No bullshit!
Very aggresive and No knock even on 14psi
Heaps of quality R32 parts available!
Will sell all $5500 CASH and include spare RB25 long motor!
Gold coast
Sam 0423 648 114
Edited by 32TAXI
Story of the 25/30!
The old rb25 had leaky valve stem seals and smoked on hard decel, but still had even comp on all.
So weighted it up to rebuilt a 25 or 30 but scored a 30 Short block, collar, cometic head gasket, new waterpump and 2x 1.2mm restrictors cheap off SAU so it started.
Bought a spare 25 head, welded water passage and vct then got full reco and 2x valves by Gilberts.
Got a New genuine N1 oil pump and Nissan gasket set, Acl bearings and Moly rings from states at the right time. Crank was sent to Probuilt, Grubscrews and collar fitted, checked and linished.
Gave the block a good clean, drilled, restricted and a light hone(slight top ring wear)Standard bores, deck and crank, new dayco belt and hi/lo tensioners, RB20DET inlet cam/sprocket as always wanted GTR covers!
I'm a Mechanic of 15 years at Nissan, In the trade as they say and was built cheap so sell cheap.
RB25/30 was built in november 2011, No forgies, No rods, supported well, never spun over 7k or 14 psi.
Just a tough street engine that pulls hard, very aggresive and runs great.
Needs a good balancer as never got around to it & VCT can be fitted via external line or internal mod if needed.
Edited by 32TAXI
What sorta deal u do on engine and turbo?
Call, inspect and go from there
Edited by 32TAXI
Motor, inlet and box SOLD
turbo, powerFC, injectors, oilcooler, splitfires and rad all available!
Edited by 32TAXI
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
