hey everyone,
wierd problem, my number plate lights have stopped working, along with 1 of the reverse lights .... has anyone incured this problem before?
I'm currently trying to find an english conversion/version of the interior fuse box to see if its a fuse problem, however a 'fuse' problem would tell me that "both" reverse lights shouldnt be working not just 1 or the other ..
did a search on here, and doesnt seem to be anyone posting this issue before, but i'm hoping someone might hvae some info on how to help with it...
cheers guys!!
reverse lights are powered thru a single 10A fuse (#71) in the fuse box behind the battery
number plate lights are powered thru a single 10A fuse (#75) in the same fuse box, which also powers your tail lights and parkers.
if either fuse was blown you would have many more lights not woking.
edit - it wont be a fuse problem but heres a quick tip. number plate bulb is a T10. you could swap it with your boot interior bulb to check if its a fuse or possibly a socket problem
reverse bulbs - just swap them around to check if its a fuse or even a poor socket. theyre an oddball T15 i think
Edited by Deep Dish V35
its a defect to have any form of light missing/broken its 1 point and $100 if im correct and it also may lead to other deffects as such
Think that you've got two different problems mate.
Try replacing the reverse light bulb and not worrying about the number plate. If people can't see it at night, that's a good thing... right?
http://www.police.ql...8/Ch_08_PT2.htm press (CTRL + F type in light)
Interesting...Got pulled for it in NSW and just claimed that I didn't realise - which I didn't (long trip from Brisbane to Sydney and was tired).
Copper allowed me to drive to a servo and pick one up. Just let me off like that, hence why I didn't think it was defectable.
Also, this was when I was in my S13 and looked like a h00n!
well got some bulbs from mate @ http://www.86forums.com.au , these LED fancy thingos, just need to get some time to try slot them in ...
and with the reverse light, my rachet broke, so i cant get the damn tail light out :( was one of those weekends
errr , im just worried about getting the lights working over the # plate :P
currently 1 reverse light still lights up a bit, sux where I live its a dark corridor to reverse down, so i've gotta feather the brake to help me see if any kids decide on doing a bolt
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
