Hi
selling my GTR34 V-spec.
Parts include:
1999
R34GTR
V-spec
White
Front bumper
Head lights
Bonnet
Front fenders
Driver side door
Passenger side door
Rear bumper
Rear boot
Rear spoiler (missing the lip)
Suspension
(fresh paint job)
Factory intercooler
Radiator
Fans
Radiator support
R34GTR Original engine
R34GTR Original Gearbox
Diff
Clutch
Front and rear seats
Dash
Parts missing:
Some intercooler pipes
Some interior trim(like door trim etc)
need some light work to make car start and run,
* will only sell the car as this condition, buyer need organize own compliance and source the parts.
Reason for sale. was plan to building the time attack GTR34. but change the project and no longer need it.
QLD area
$29,500
End of this week? No offence, but if the details are all correct - you'll should have buyers already lined up by this evening! Get them up ASAP I say
Very interested in the car. Waiting on pics!!
will take few pics end of the week
How many km's?
Have you got all the import papers?
please send me your contact number. will call you to discuss
cheers
so whats the go with the steering wheel? has it been in an accident?
looks like its had a respray, timing belt cover off (damaged?)
air bag out?
drivers seats out , why? was the old seats the ones with factory air bags hence why there replaced?
strut brace out?
i might be interested but these are the things i think about when i see this
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
