Hey.. the foam in my drivers seat has always been rather thin on the drivers door side edge. I am guessing a lot are like this as while searching for a second hand seat they've all had this wrong with them. Just wondering if anyone's tried replacing the foam? Ive never done anything like this but might have a play and see what i can do.
https://www.sau.com.au/forums/topic/407586-r34-seats-replacing-foam/
Time then to talk to your local Trimmer to see what's involved I think > watch him working on such a task if he'll let you.
I'm old enough to remember how flat chested women used to stuff their bras and try to get a 'smooth look' only to shake my head and walk away.
If you pay more than $100 you getting ripped.
As for a diy depends on your skill.
The covers are glued to the foam. You only need to peel the cover off the side where the foam has collapsed. Cut the section of of foam out and glue a new peice in then shape it.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
