Sooo many R33s being wrecked on here, someone got handbrake cables at a decent price for me?
I won't need the hubs and rotor/caliper but if you just want to get rid of it all for cheap I'll take it.
PM or TXT
O41O SEVEN NINE SEVEN 996
thanks.
p.s. I'm located on the Central Coast (NSW), can travel to sydney or newcastle.
https://www.sau.com.au/forums/topic/407635-wanted-r33-handbrake-cables/
Hes not a scammer mate he is a great guy i know him personally he just works on a farm so sometimes its hard for him to get to the net to check. I garuntee you wont have a problem with this dude.
Enjoy
