so, ive got an os giken twin plate clutch for sale.
suit push type rb.
has been rebuilt approx 4-5,000km ago.
has seen some launches.(lets not kid ourselves)
clutch plate centres are os giken, puk style.
good for around 600hp, drives suprisingly well.
not too heavy, has a bit of bite, but you get used to it.
moving to a box with a holinger input shaft.
$850.
sorry, dont want to post at the moment.
also have m's pods to suit gtr.
with filters(k&n style).
$100
r32 gtr gearboxes x2
1x just came out of running car.
does crunch when shifting fast to 3rd and 4th
sounds like it has straight cut gear set, IT DOES NOT!
comes with transfer case.
no shifter included.
1x bought 2nd hand.
unknown condition.
$400ea, or make an offer.
will add more as i find it, upgrade it....
pm me on here for more details.
  • 3 weeks later...
  • 4 weeks later...
  • 3 months later...
price drop!
twin turbo pipe with splitter welded in, 150!
THATS INSANE!!!
gearboxes now half price!
get these rebuilt whilst still driving yours.
  • 1 month later...
  • 1 month later...
  • 5 months later...
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
