Hi for sale is my pride and joy 35 stagea. The car has a few rarer options making it a very nice car.
From the factory:
Black leather (not fugly tan vomit)
electric seats, 4 way driver, 2 way passenger with the heaters
Climate control, pwr windows and mirrors but i think these are standard on all 35's.
vq25det, 5 speed tiptronic, awd etc.
Non factory bits:
Fully body kit, not 100% sure who is the manufacturer but ive not seen it on another personally. Front bar totally overhauled repaired and painted last week
18's
Hi flowed turbo (mike vine)
Since hi flowing installed a hdi ebc, hi setting 15psi for safety. Turbo good for heaps more if you want to do injectors etc
Custom 3" dump. remainder of exhaust is factory so its plenty quiet but the hard bit is done for potential buyer. ( i have a wife and kids)
BC Racing coilovers
Greddy FMIC
Boost gauge (factory one does not work)
Nismo 280km speedo (not speed limited)
Always serviced with synthetics, 6 months rego, will have rwc for buyer.
car turns heads yet never been pulled over in it.... (must be the volvo look :)
$18000
0411897467 or [email protected]. Please do not call after 7:30pm as i have 2 young boys and my wife will hunt you down mercilesly if you wake them when my phone rings. You should be able to get me anytime during the day from 6:30 am
Brisbane area
Edited by The original Badger
Thanks man, I appreciate that. I didnt know there was one. M35 Stagea.info wouldn't upload my ad. Sucks
on here there is a stagea forumn. Just open forumn link and in stagea section. most of stagea.info guys are in stagea discussion section
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
