Hey people, im pretty new to the site.
My names Bevan and im from the central coast nsw, just bought a pretty clean black s2 R33 Gts-t.
Its got basic mods atm, such as:
3" jjr front/dump
3" Catco high flow cat
3" Kakimoto cat back
Blitz return flow fmic
Blitz pod
Walbro gss342 pump
Running 9psi
Gtr wing
Future plans are, Nistune from Jez, maybe better turbo, depends if i want 200kw or 250 i guess lol
Bc coilovers from STT
Rota Grids possibly
Other supporting mods etc
Very keen to meet some new people and go on some cruises.
Edited by Bw33zy
https://www.sau.com.au/forums/topic/410557-nsw-new-to-the-site-s2-r33/
Well the rotas are ordered, so just shopping for some coilovers :)
Hey mate, welcome!
There is a cruise on the 21st down old pac... Newy and Central Coast cruise :)
Get BC BR from STT if that's where u are buying...
Hey man, where bouts on the coast?
Yeah sounds good, keen to get my wheels on and some coilovers :)
Hey man, IF u do get out on the 21st just lemme know as its starting to get pretty big and I'm gunna need to change a few details on the cruise lol.... We are already over 20 cars and it's early days :D
whoa, 20, better slow down there.
going to no one left in newcastle...
jokes.
but srs, wish my car was running, would be in on this.
jokes.
Haha there is plenty more but the place we are stopping at has a fair bit of room but I dunno how many it'll really hold! Hence why I'm keeping tabs on it the best I can lol.... And your barge ass GTRs take up as much room as 2 GTTs :P
