I bought the car as a shell and built it from there. Huge list of modifications do not want to know price to build car 95% of all parts purchased brand new. This car drives amazingly and is a complete animal, not to mention has the looks to match. You will notice in the pictures the unfinished front guards. This is due to not having wheel lips for my 18" equips, so i never got around to completing a set. Some aggressive FRP guards could be bolted on to set it right off ! Car is always looked after / garaged and serviced only with Mobil products. Also gets plenty of attention at the track =P
I too have no problem sending this interstate I've used a very good company before bringing a car up from VIC.
Price = $22000
Engine - Build Buy KJ Motor Machining, Kohen builds drag racing engines to blueprint with extreme tolerances, the motor cost a f**ktonne.
The car had no Odo, but it wouldn't even be close to 5000km, gearbox was rebuilt at same time as motor. It was also built for 30psi roughly 600HP.
Mahl pistons
Scat rods w arp fasteners
Mls headgasket
Acl mains
Arp big end fasteners
Arp head fasteners
Arp main fasteners
Ati balancer
Supertech valve springs
Re-welsh plugged
Tourqe plate honed to .20thou
Oil galleries drilled larger / tapped
Valve seats re-cut / valves faced
Crank collar welded / machined / re-ground
Block n Head re-faced
Balanced, Rotated n blueprinted.
Head ported / knife edged
Garrett Gt3076 .8 (rebuild by garrett when engine was built)
Hks 264 9mm cams non-vct
6boost forward highmount - head wrapped
Turbosmart 38mm Wastegate
Freddy plennum faced and port matched
Decs 550cc inj
Q45 TB
Carbon Fiber Cam cover & plug cover
Nismo FPR
Mezier waterpump (controlled by haltech to act as thermostat)
NPC lighten flywheel n 5 puck cushion
Rebuilt 25box
PWR xflow GTR radiator
PWR custom Intercooler
PWR oilcooler w. Enzed Lines
PWR powersteering cooler
Motor into firewall 1.5 Cyl
Fuel cell w. Surge & Dual Walbro pumps
1.5 to 2" screamer pipe
Full 3" Exhaust wrapped
Extreme Custom Engineering 2x4" twin tip exhaust
Suspension
PBM Coilovers 10/8
PBM LCA front / rear
PBM toe
PBM camber
PBM castor
PBM traction
PBM cradle risers
Driftworks Hubs (modified for dual caliper)
Whiteline Adjustable sway bar front / rear
Extreme Custom Engineering catch can, with drainback
Drivetrain
rb25 box (rebuilt same time as motor, new 3/4th synchro & bearings all round) by DANSTRANS
Urethane Mounts
npc lighten flywheel
5puck clutch
Quartermaster hydraulic throwout bearing
Hardy Spicer 1 piece tailshaft
Kaaz 2way
R33 Gtst Brakes w. DBA rotors w. QFM pads
Dual Calipers for separate Hydro
Electrics
Haltech PS2000
Racepak IQ3
Wideband Controller w. Sensor
Boost Control Solinoid
Oil Pressure
Oil Temperature
Water Temperature
Air Temerature
3bar Map Sensor
Haltech TPS Sensor
Standalone LS1 coilpacks with custom Eagle plug leads
MR2 Electric Power steering pump mounted in boot.
Single engine loom plug on firewall
Full rewire with a EZ kit
Switch panel's control everything
Exterior
Onevia Conversion
Tinted red taillights
Dmax type 3 kit
Dmax type bonnet vent
Dmax roof lip
Custom Metal Widebody
Painted Black
Interior
Bride ZetaIII drivers seat
PBM hydro w. Tilton master
S15 Dash
Tilton floor mount pedal box w. Tilton masters
Chassis
Fully Stitch welded, underside aswell
Rear firewall, due to fuelcell
Notched firewall for motor to sit back 1 1/2 cylinders
Framed rear end, for fuel cell
Huge front tubs
Rear Tubs w. metal widebody
Tubed front Reo, sits tight in frontbar
Wheels
Front - 18x8.5 SSR Vienna
Rear - 19x10.5 +12 Varrstoen (x4)
The work equips are not included in the price but could be negotiated.
Power
450rwhp @ 17psi tuned by Chris @ Bob Romano's
Spares
2 x 5bolt drive shaft
4:1 Diff gears w. housing
2 x Tilton master cylinders
Tilton Remote brake bias adjuster
Steering Rack
Whatever else i can find for it
Pictures
I'm sure there is allot I've forgotten i can be reached on 0420 855 181 if you have any questions or want to check it out. I will continue to drive this at the track until sold.
I've f**ked up the price its $19,500 with the SSR Viennas / Varstoens.
$22,000 with the equips (18x9.5 front 19x10 rear) there not shown in the photo, will have updated pics soon.
chrome equips 19x10 19x11 are $2800 extra
great build.... very impressive sad that u want to sell her.... off topic i know but did the stiching the rear make a difference ?
whole things stitched, only time u no the difference is when you jack one corner it goes up level and u can balance wheels opposite corners on curbs, not that i can get this out my driveway =[
would make an awesome car for competition, hopefully have some decent pictures up within a few weeks, got a bloke wanting to shoot it =P
This is the hottest car i have seen on this forum. id buy it for 22 tomorrow!
and you haven't contacted me why? haha
if your actually serious and not just slinging jokes call me 0420 855 181
peace
sorry maybe i shouldve worded that better. id pay 22k for that tomorrow as in, i think its worth that and if i had 22k id come and buy it, congrats on building such an epic car, but i dont have 22k to come down and get it!
bump, can do an extreme package
car + 8 work equips + 4 varstoens + dual axle trailer (tyre rack, elec winch, toolbox) = $29,000
will include every Nissan part and car related parts i own.
  • 1 month later...
  • anyone wanna swap a basic s13 or s14 + cash?
  • something along the lines of Sr manual, t28bb, coil overs, 2way, castor / camber / toe arms
  • 1 month later...
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
