For Sale/swap Rb26Dett New Garrett -5S Complete Setup
Hi Guys I have just spent the last 2 years building up my R32 GTR and bought everything to run twin Garrett 2860-5's. This setup has NEVER been used other than 10-15 minutes of running at idle. The car hasnt been driven so it is as new. I had to remove my engine again yesterday and have decided I want to go single instead of sticking with the twins. So I want to sell/swap this setup. Everything is made for a 32 but would probably fit 33 as well.
Kit includes:
-Brand new Garrett 2860-5's only run for 20 minutes MAX at idle x2
-Custom stainless low mount stock position manifolds x2
-Xforce split stainless dump pipes bought second hand but in excellent condition also heat wrapped x2
-Stainless y-pipe I think it's 2.75 into 3.25 but i'll check
-Complete custom 3 inch stainless piping turbo's to airflow metres to stock blowoff valve hard pipe
-Custom 3 inch alloy pipe from twin turbo pipe to cooler
-Factory 2 into 1 twin turbo pipe
-All oil lines, water lines, oil drains, metal gaskets, silicone joiners, clamps etc. full bolt on package.
The manifolds we're made By Ryan Capel from Capel motorsports and are of the best quality stock position low mount manifolds around. The only other car with these manifolds is the car that used to be known as "TWOOGLE" My mate did all the piping and it looks really good in the engine bay I have only shitty just jap mushroom filters on at the moment but the piping was made with the 150mm hks mushroom filters in mind.
I'm looking to put on a high mount GT35/40 on it so if anyone out there is thinking of swapping back to twins then hit me up and we could work something out.
I know I'm obviously not gonna get all my money back but I'd like to offset most of the cost so I'm looking for around $3400.
post-58307-0-57237400-1351235227_thumb.jpg post-58307-0-00974600-1351235346_thumb.jpg post-58307-0-38088200-1351235372_thumb.jpg post-58307-0-45103200-1351235424_thumb.jpg post-58307-0-60614400-1351235442_thumb.jpg post-58307-0-52281600-1351235461_thumb.jpg post-58307-0-71891300-1351235483_thumb.jpg post-58307-0-28530900-1351235503_thumb.jpg post-58307-0-58251800-1351235527_thumb.jpg post-58307-0-80420600-1351235654_thumb.jpg post-58307-0-10704800-1351235760_thumb.jpg post-58307-0-51992900-1351235776_thumb.jpg post-58307-0-32450200-1351235796_thumb.jpg post-58307-0-56913100-1351235816_thumb.jpg post-58307-0-65826900-1351235838_thumb.jpg post-58307-0-68145100-1351235884_thumb.jpg post-58307-0-77072700-1351235906_thumb.jpg
Didn't you end up with the other set? They're the thing thats going to be hardest to part with thats for sure. It is a great kit I've just got my sook on because I've already taken turbo's on and off this car 4 times and now I have to do it again I really cant be f**ked. Plus I said that if I ever took them off again I'd go single and I'm worried my car will keep presenting me with problems till I do as a form of punishment lol.
He never made any, not for me anyway.
Shame you didn't put them up when u pulled it apart, would of taken them!
Keep it twin!
Edited by jangles
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
