i have a few random bit for sale as i want to clean out my garage.
RB30 block & girdle, was keeping it for a 26/30 build, had a change of plans soo its not needed, has threaded holes for oil & water lines oil return ect, also has the machined face on the front for the twin cam idler pully.
$100 ono
post-86035-0-57818300-1354155232_thumb.jpgpost-86035-0-39426300-1354155277_thumb.jpgpost-86035-0-05880200-1354155542_thumb.jpg
standard RB26 exhaust manifolds, dump pipes & heat shields
$25 ono
RB26 standard flywheel, not needed as i but a npc billet flywheel on when i did clutch change
$50 ono
245/40/18 BF GOODRICH tyres good tread. came off my 260RS stagea as the rears were worn & the rolling diameter difference between front n rear was interfering with atessa.
$50 ono
Items are located in Ipswich qld & tyres sold pending payment
Edited by GTR260
Manifolds ,dumps & heat shields sold pending payment.
Still for sale,
Rb30 block
Rb26 flywheel
Rb26 standard injectors
Manifolds, dumps & heat shields sold.
Someone make offers on the rest! Would like this stuff gone
    • I have been wondering if this is as simple as a voltage issue with the battery. Even on a charger, I can’t seem to get it over 11.8V on the terminals.    Unless the alternator has failed as well, that wouldn’t cause it to die in the middle of driving though.
    • I’ll give this a shot next time I’m able to wrench on it.    I was able to get my hands on a Haltech Nexus, so that should help with some of the more bizarre troubleshooting. Make sure the CAS is actually sending signal and will be able to set the proper dwell on the R35 coils.    I’ve checked power/grounds/signals at the CAS, ignitor, and plugs and it was all there. Granted this was static with ignition on, not cranking.    I also plan on swapping out the fuel filter and throwing on a fuel pressure gauge at the rail just to confirm I’m getting the correct pressure at the rail. 43psi if I recall correctly.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
