G'day all
My first Skyline (R32 GTS-T) will be arriving next week, so I thought that I'd join the community and say G'day.
I'm looking to get a few extra KW out of this puppy, so I'm after a 3" mandrel bent exhaust from my VG30 roller-bearing turbo back. Can anyone recommend an exhaust shop in the northern suburbs of Melbourne that will look after me? I'd prefer one that can provide a quality dump pipe as well.
Regards
Tony
https://www.sau.com.au/forums/topic/41480-r33-dump-pipe-exhaust/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
