Hey guys i'm having some issues starting up my 08 gtr and wanted to get some help. Obvious first check was the battery, got the multimeter on it and shows good charge so probably not the battery. The car ignition won't even come on so it won't kick over. Did some searching through the forums and so i've found out about the common steering lock issue with earlier models =(
Anyway thought i'd try dropping steering rack unplugging the steering lock unit, clean it and re plugged it. Still nothing.
I don't have an OBDII reader so got an electrician to come out, he plugged his scanner in and it came out with steer lock reset id - now he reckons I need the original password to unlock it to get the car started?
What do you guys think?
Cheers,
Ken
https://www.sau.com.au/forums/topic/414805-possible-steering-lock-issue/
Quick update: Electrician called me back and said it's most likely my steering lock unit is faulty.
Have any of you guys replaced the steering lock unit? Since its a Jap model would ordering american parts still fit up fine?
And would you guys recommend any oem nissan parts sellers in America?
Everthingnissan,com seem to have these two part numbers available 48700–JF00C & 2x 48703–06F0A which i think is needed but have never tried purchasing from them.
Thanks
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
