  • Replies 48
GTR's have a front facing plenum dont they?? Its made for a GTSt but the only part needed to be changed would be the top return pipe. The in pipe comes from the passenger wheel arch (std positiion) then the out pipe goes to the drivers wheel arch. All u would need is to have a pipe made to go from the weel arch to your throttle body...
**** this is a good price ppl!
FMIC's on all RB20 and RB25's decrease lag!
Colder intake air= quicker combustion= more power earlier = Quicker spool
A mate picked at 20 rwkw with his custom FMIC and my younger brother got 22 with a similar kit
Guys I bought this kit for $1100 (which is Damn cheap as it is) Why would i turn around and sell it at a loss to myself. Unique Autosports sell a similar kit for $1695, so why PM me with offers less than $1000???
$1100 - NO OFFERS INCLUDES COURIER FEES TO ANYWHERE IN AUSTRALIA !!
If u can do better than buy it.....
Its still available ;)
Its actually a pretty good designed core. Its a hybrid between bar and plate and tube and fin, so you get the best of both designs. Bar and plate cool better, and tube and fin have less pressure drop so this would go awesome on any r32....I think they said intake temps went from 65 degrees to something like 23 with this kit.
This is more than enough for any r32 (unless u want to punch out big hp numbers like me ;))
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
