Okay have an obundance of V8 supercar 17inch magnesium wheels I want to get out of the workshop.
We have upgraded most cars to the current (2012) team dynamics alloys so these are redundant to me now.
Some are black some white. They are the 5 spoke speed line design wheels run on VT-VY before they went to OZ racing wheels.
Condition varies from perfect near new to straight but chipped powder coat all the way to smashed and damaged.
A lot of these have only been used in DVS others are ex HRT, if someone wants one signed buy a 888, GRM or teckno driver I can arrange something for them at the upcoming test day.
Perfect wheels $250
Damaged wheels $150
Smashed wheels $50
Have piles of tires that can be mounted to the rim for free if desired
Pick up only from Campbeltown.
Silly question probably but what width and offset are they? I have a few mates chasing some cool 5/120 wheels.
Edited by Hank Scorpio
They are a controlled 11inch wide rim with a roughly + 30 offset that can be machined by the teams to whatever they want. So offsets could be anything.
These are all a centre lock type rim that uses 5 drive pegs and centre lock nut.
A lot of the tires are stil usable.
I don't like your chances of fitting them under skyline guards though. The profile is twice what you'd normally want to run.
Call sonic if your looking for just tires come down one afternoon and go rummaging through the mezzanine floor. There is probably 50 odd tires of various sizes you might find something that suits
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
