  • Replies 42
not too much, it does seem to sit a bit flatter when taking corners at normal speed, but I don't feel like I can push it through corners faster than before.
I was a bit worried about the comfort level as I have the revised rear 350Z springs which have a higher spring rate than the standard V. but I can't really notice it..
I am fairly happy with how it looks.. I didn't really like the look of the front with the stock springs, especially with the smaller front tyres..
If I had a square that size, I could do some comparisons. Although my rears are aligned to spec, and the fronts don't seem to be that bad on mine..
Do you know how much camber that is on yours?
rear is -3.5* naturally. front is about -1.5*
front look almost uncambered in comparison, if i bought camber arms for the front to make it -3.5* all round, i'd need to space my front wheels out 15mm to correct the guard flushness
if i went another inch lower, the rears will be -4.5* due to IRS, front will stay about the same
Edited by Deep Dish V35
Thanks.
Still trying to work out the differences between the 350z suspension and the V35 sedan suspension.. if it is just the springs and shocks, it doesn't explain why the camber on a stock 350z is fine, but fitting the 350z springs in a V35 causes camber issues?? especially since there is no camber adjustment on the front.. Everything I read says everything else is the same.. just trying to get my head around it..
the 350z springs and shocks are shorter than v35 units, you are lowering the v35 by fitting the 350z items. when you lower the V35 the rear camber increases much more than the front just by design
sure, but the rear has camber adjustment from factory, they aligner was able to get mine in spec with 350z springs, but the front only has toe.. so why does the 350z front have -0.3deg camber and a v35 with 350z springs have closer to -1.5deg? something has to be different? or am I missing something really obvious?
Yeah, but if everything else is the same, why would those angles be different between a stock 350z and a V35 with 350z springs?
If you put V35 sedan springs in a 350z, do you end up with a + camber? And if so, why? What else is different?
the main difference is the height of the top tower mount. the 350z body has a lower profile, so they made the tower mount lower, which required shorter suspension.
this is difficult to explain....
on the front wheels, the camber changes because the hub follows geometry based around its "king pin inclination", which is the position of the upper and lower pivot points of the hub. the top pivot point is always positioned further into the car. as a result, the upper arm is usually shorter. the difference in length between the upper and lower arm means that both have a different rotational radius which creates a slight amount of camber as the arms compress upwards. The other factor is the upper and lower arm angle. these arms are never designed to be parallel, so each arm is in a different stage of its rotational length....
if the arms were equal length and parallel, the wheel would always have the same camber. this is no good for cornering.
the difference between the front and rear suspension is that the front has 2 vertical pivot points, where as the rear has only one. with one pivot point, the rear's camber increases dramatically. with 2 pivot points on the front, the suspension stays more square
the arms are designed to be a certain angle at standard height, the correct angle of the arm on both cars has a different distance to the top tower mount, hence the longer strut/spring in the v35
its kinda hard to describe without drawing pictures
I understand that.. but if you fit 350z springs and shocks in a V35, and there are no other suspension differences.. therefore a stock 350z, and V35 with 350z springs should have all suspension arms at the same angle.. so why is the camber different between the 2 vehicles when there is no camber adjustment? there must be some other differences with the suspenion.. the weight difference between the 2 is quite small, so I doubt that is causing it.
Edited by sonicii
the other thing is: even though the suspension parts are the same, the bodies are not. the obvious difference is the height of the strut tower, but then the body mounting points for the suspension arms could be slightly different too...
Thanks for the info.. it was quite good.
I think I understand.. correct me if I am wrong..
because the 350z has a different strut mount height in relation the suspension, the 350Z suspension arms with stock 350z springs sit at approximatly the same angle as the suspension arms in a V35 with stock V35 springs?
so a V35 with 350Z springs has the arms at different angles when compared to a stock 350z?
Meaning the subframe is actually closer to the road on a V35 with 350z springs than it is on a stock 350z?
Edited by sonicii
i can only say : in theory that is correct. i have not physically measured a 350z...
the only other difference i can think of is the body mounting points. every part is designed to work at certain angles on a particular car, and a 350z is not a v35. each model may have body mount differences to encourage different suspension geometry... they can dial in different rates by changing mounting points. even moving the tower top closer to the centre of the car changes things such as spring rates...
you cant just throw together good suspension, it involves hundreds of calculations and variables. and changing just one point can affect many other things. even widening your wheel track affects the suspension rate marginally
considering that all mechanical parts except shocks and springs are identical, you would have to measure the difference between the wheel mounting faces, the tower tops, the arm's body mounting points (width and height) to see if there are any that dont match.
its seriously complex.
When i put my new 350z springs + shocks in soon, my main concern is the side skirts on the Coupe sits very low as it is with standard suspension.
With these lower springs i hope i don't wedge my car on a speed hump is all lol
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
