Up for sale 2 sets of 4-point Takata harnesses including the mounting parts to secure them into the car. Hardly used, mint. 300 dollars each plus shipping or pick-up from Adelaide.
Hi, Lou
Will have first dip at the pair subject to verification of date of manufacture and " genuine Takata ? ) please send pics with all tags to 0433878905
Do you have receipt and condition of harness
For clarifications! one harness for the driver side and another one can be used for the passenger side, not two for driver and another two for passanger.
After a SAU member brought to my intention in regards of harnesses validaty after the year stated on the harness, I decided to do more research to clarify what I know w/ respect to the Cams Rules & Regulations and FIA interpretation. In addition, I've contacted two professional national track participants, and they also confirmed what I am going to share w/ you shortly. Furthermore, I surfacely touched the ADRPG rules regarding the harnesses requirements on the tracks. At the end of the day, all sites I visited refer back to the Cams rules.
Briefly, Takata has stated on the harnesses I have "Not Valid after 2010." Based on the Cams rules, the harnesses are still good for use in any events (except of international ones) until 31st of Dec 2015 but after being inspected by event organisers/inpectors. The inspectors usually look for worn harnesses, damaged latches, etc... As long as the harnesses are not torn, not damaged, have working latches, all stitches there, etc..., the harnesses are good to go for the event.
Even after 31st of Dec 2015, you still can use them outside of the track for your show car if you like.
I am attaching a couple of documents to show you what I found in Cams and also from other sites. In these documents, I've circled and underlined key points of the matter. You can also look into it as well if interested and let me know if I missed anything.
As I said before, the harnesses were hardly used, not brand new, genuine, and they do not show any signs of wear, tear, damage, etc... If you want to buy a brand-new genuine Takata harnesses (dated 2015 and above), expect to spend around $600 dollars or more for each set.
Hope this clarifies it.
Thanks,
Lou
Got tired of accepting offers and then people do not bother responding. If you are not up to it, please do not waste my time. Thanks.
Should have an accurate description of what is being recieved. Not waiting
for an offer to be made then adding "by the way these wont be included".
Also after checking progress of recent sales, accuracy of other item descriptions (misleading information on Recaro seats) and previous sales history Im no longer confident in transferring funds. I cant be the only trader with these views, evidence being the difficulty you are having selling items and constant questions of authenticity.
Please do not waste my time. Thanks
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
