Up for sale is my 1999 nissan stagea 260rs [genuine autech version]
I have owned it for two going on three years now and think its time to move on. Since owning it I have resprayed it sliver [standard colour] just to neaten it up as when I got it their was a few scratches and dent here and their. I have also spent a fair bit on it to get it where I wanted it.
The engine has been fully rebuilt with the following done:
-valve service cylinder head
-machine tappet shims to specs
-260 tomei poncam camsharfts
-JE forged pistons
-bore and hone
-h series bearings
-all hoses were replaced
-nitto metal head gasket
-nitto intake gasket
-nitto exhaust gasket
-apr head stud kit
-new standared thermostat and gaskit
-all fan belts
-35r garret turbo and waste gate [plumbed back]
-turbo benni
-custom exhaust manifold
-200 cell high flow cat
-custom 4inch exhaust with 2xmagna flow mufflers to keep it legal
-hdi intercooler [i think cant remember]
-1000cc injectors [not sure of brand]
-walbro 400lph intank fuel pump
-adjustable cam gears
-hdi electronic boost controller type r
-evo boost gauge
-2xdrift pod filters
-hks induction pipe kit
-clear timing belt cover
-new timing belt
-nistune ecu
-jjr oil catch can [return feed so you don’t have to empty]
-hcb heavy duty clutch
-clutch assy cylinder + hose
-power steer rack was pulled out and serviced because of leak
-smoked side indicators
-19inch prodrive seven spoke grey rims [little bit of gutter rush from previous owner]
-head light eyebrows [keeps the lights from going yellow]
-some sort of immobilizer [not sure of the brand came with the car]
The car made 339.4kw @ all 4 wheels but I was only running bp95 and an air flow meter was playing up,since then I have replaced an air flow meter but just haven’t had time to get it retuned!
The engine has been built to handle over 450kw and can be achieved by upgrading to spitfire coil packs with a retune a new ecu may be needed depending on how much more power you want.
The car is immaculate inside and out apart from the front and rear bars which will be resprayed due to them having some scratches
I have also put new bridgestone 245/40/19 tyers all round
The car gets serviced EVERY 5,000kms religiously!
Rego 20th September 2013
Alot of time effort and money has gone into this car for you to enjoy!
I have all receipts and dyno sheets
The car has just clicked over 100,000kms
The engine has done 5,000kms
Im asking 27,000 which I think is a fair price
NO TIME WASTERS PLEASE
ONLY I WILL BE DRIVING UNTILL DEPOSIT HAS BEEN TAKEN!
LOCATION SYDNEY NSW 2100
i will add photos tomorrow
also a few things i forgot to mension
-comes with nismo floor matts
-tinted front windows to match the back
- the rain strips have been painted black to get rid of the god awfull purple colour that they turn
-roof racks that i havent had the need to use yet
-standared brembo brakes
-and comes with cargo net & blind
Having personally been in this car a few times, I can certainly vouch for its cleanliness and power.
Whoever buys this will be VERY happy with it, no expense spared.
Edited by XS80ST
  • 1 year later...
ok car is back up for sale again. I have since resprayed both the front and rear bumper bars due to scratches
and have also purchased a plastic dayz front bar which was also sprayed and fitted to the car to replace as the autech front bar as it is fiberglass.
I still have the autech front bar wrapped up in mint condition to be sold with the car. I have also put 22mm spacers back and front [wheels] to give the car a better look
the car now has 113,xxxkms on it reason for selling is I have bought a motor bike as a daily so the car just sits in the garage under a cover most of the time now
price $27,000
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
