ALL LOCATED IN SYDNEY NSW CANNOT POST BUT CAN MEET SOMEWHERE LOCAL
REASON FOR SALE IS I HAVE RUN OUT OF SPACE AND TIME TO SELL IT ALL OFF INDIVIDUALLY SO SOMEONE ELSE CAN BUY THIS AND MAKE THERE MONEY
SHOULD BE 2k WORTH OF PARTS HERE
ALL OFF R34 GTT WITH 88,000k
Rear bumper white - undamaged
Front crossmember with steering rack x2
Front uprights with 5 stud hubs
Rear knuckles
Front radiator support panel - undamaged cut at the strut towers
Front strut brace
Rear subframe with all arms and hicas motor
second hicas motor
Drivers side 2 peice side skirt
Drivers side door - dinted but good for internals
Rear spoiler - undamaged
front underbody tray - still intact (rare)
Complete airbox with factory snorkel (seen going for up to $300 on ebay)
Has all standard castor rods and lower control arms
Comes with custom airbox
Comes with custom 3" exhuast system
NEED IT ALL GONE ASAP
SOMEONE ELSE CAN SELL AND MAKE THERE MONEY BUT ID LIKE $500 FOR THE LOT AS I NEED THE SPACE
VERY POSSIBLE THERES STUFF I FORGOT TO MENTION AND WILL ALL BE THROWN IN!!!
CONTACT TIM ON 0404321205
Wow thats cheap only if u were in melbourne i would get them today
3 of those items is already worth $500 alone...
Edited by Johnie
Also theres a bonnet, which has a few dints in it maybe able to be repaired.
AND 2x Xenon HEADLIGHTS THAT THE LENSES ARE BROKEN BUT PERFECT OTHERWISE MEANING YOU COULD MAKE YOUR NON XENON INTO THESE
Have heaps more little things
ALSO HAVE STANDARD R34 WHEELS FOR SEPERATE SALE
Sorry your in VIC lol would love you to come get it all
Also forgot theres a full set of immaculate floor mats front and back and tunnel cover thats 5pcs included too
Ill keep thinking of stuff
Someone come buy it all
would like front underbody tray + clips (actually i only really need the clips)
and possibly driver side door card + clips
wtf is with my lack of clips.
BLITZ-26 if you do end up picking up all this do you mind me shotgunning those parts?
You can find plenty of clips at Supercheap :)
Is any of this still available? Or is the new owner selling anything?
I may be interested in:
Front strut brace
Drivers side door switches and/or panel (depending on year model)
Exhaust
Floor mats etc
Let me know!
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
