Hey all,
Having a post holiday garage clear out
All items are in good used condition unless otherwise stated.
all located in Kealba Vic but will to post at buyers expense
Please only contact me on 0417585108
No swaps on anything thanks
Microtech LTX8 with all bells and whistles - $850
sequential ignition for 4cyl and rotary engines, can suit 6cy, 8cy etc
curently set up for Toyota 4age engine
Genuine HKS SSQV BOV - $100
mount included for toyota 2JZ-GTE but can fit any boosted engine
Turbosmart dual stage boost contoller - $130
Amps and Sub - $160
Coustic 481QE 4 channel 480watt amp
Clarion APA250 2 channel amp
Clarion PA12-S Sub
3 MAXXIS MA-V1 225/45/17 tyres with viper rims - $200
Dated 16th week of 2009
Viper rims that were on a nissan silvia so stud pattern is 4 x 114.3
Subaru WRX seats - $220
1999 model, some minor marks on material and driver side rail has mounts cut
Toyota JZA80 RZ front seats - $70
need a good steam clean, unknown condition of driver side motors
Nissan s13 power steering rack - $100
came from an S13 with a CA18DET
Toyota AE111 front right guard - $70
spray can black so would properly need a paint strip
Toyota AE86 FRP rear fender flares - $150
Brand new, I've gone in a different direction. I bought these from the states
  • 2 months later...
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
