Ok i went and got my c210 roadworthied today, he was happy with majority bar: gearstick boot cover(forgot to put it on...), play in front door and the centre 2 lights not working, first 2 are an easy fix but the lights have me puzzled. Are these meant to come on when you pull the highbeam switch im not sure if theres a stuffed relay or something or if me and the mechanic were pressing the wrong buttons, any help would be great:)
https://www.sau.com.au/forums/topic/419441-c210-highbeams/
As Socs says, pull the control stalk towards you to flash your high beams. As soon as you release the control stalk it goes back to centre and the high beams go off again. If you push the stalk away from you it should stay in position and the high beams should stay on, and you should get a blue light on your dash.
First, replace the fuse.
Then, you can test if the inner sealed beams (high beam) are dead by unplugging the cables at the back of the high beam and swapping them over to your (outer) low beams. If the low beams work when you pull on the control stalk then you know that the switch and fuse etc are all fine, it's just the sealed beam that has given up. The sealed beams from memory are a generic item from Bursons/ebay etc (5 and 3/4 inch?) and only three screws to remove and replace.
Good luck.
https://www.sau.com.au/forums/topic/419441-c210-highbeams/#findComment-6740433
Got it all sorted today, it was just the lights were blown, got some from a mates 200b and voila there was light. I thought it may have been user error as on 180bs you need to turn all sorts of knobs and shit to make the lights work but this is much simpler, i shall be registering the old girl tomorrow:)
https://www.sau.com.au/forums/topic/419441-c210-highbeams/#findComment-6741733
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
