hey everyone, not sure if im posting this in the right place or not, sorry if i am.
i was looking at the car the other day and i saw all these fuel lines running in front of the radiator
i followed it and it leads to this weird what i think is aftermarket charcoal canister, i was looking around trying to find what its called and how its hooked up but with no avail.
the one in mine is weird is should be like the one with red around it, mine is the one with the fuel filter to no where filled with crap.
what would be my best option. leave it or return it to stock?
https://www.sau.com.au/forums/topic/421796-r33-fuel-systems/
  • 4 weeks later...
