nissan s13 part out let me know what yous need
engine ca18det with new acl metal head gasket
compression test was done and got 150 psi though all 4 cylinders here some parts
all panels available car is complete here are some parts
after market radiator with new hoses
intercooler
apexi pod filter
z32 air flow meter
gtr 444cc injectors
modified intake manifold with r32 tb
t28 turbo
boost controller
after market fuel pressure regulator
split fire coil packs
oil catch can
manual gear box with new clucth
blitz bov
3" exhaust front pipe with high flow cat stainless steel modified to fit the sr20 t28 turbo
engine damper
gktech metal bash plate
lsd diff
nistune ecu
exterior
*after market corner lights and front bar indecaters
*aftermarket alteza rear lights
*drift teks 17*8 all round
triple projector headlights
silvia grill
interior
*gtr front seats
*180sx door trims and glove box with factory option cool box
*type x rear seat
*digital climate control
digital speedo with hud display had it reconditioned
type x leather stitch steering wheel
silvia factory option floor mats
suspension and brakes
bm44 master
cusco coilovers
front stut brace
controll arm brace
fender bracing
in cabon floor brace
diff brace
white line rear sway bar
s15 front calipers pads recently changed slotted front rottors rear brakes have new pads and cross drilled slotted rotors
call or text me if interested 0432-062-780
will let you know the prices located in melbourne
hey mate would you sell the starter motor?
would you know if the cluster would work with any ca18det, as mine isn't digital?
Edited by Beau.r
  • 1 month later...
  • 1 month later...
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
