Well, this is aggravating. The engine was prior flooded, but I managed to get that sorted out, but I noticed that the car is quite frankly running like hell. Idling, and at any point in the RMP band, the old RB misses almost to the point of un-driveable, but when it hits mid-rpm range, it struggles to keep any power at all, often cutting out completely unless I let off the throttle. I can very slowly nurse it past the point of it dying by gradually raising the RPMs, running it all the way up the band, but the moment I blip it, I can almost kill the car at 20 kph. Then, if it is parked and sits overnight, I can't get it started for the life of me. It will crank and crank all day, but never a hint of firing unless I completely replace the spark plugs. It's got a brand new set of spark plugs, and my fuel pressure is nominal. I have read lots of things about the coil packs arcing out and messing up the spark, so I'm going to liquid tape them, and I plan on replacing all my old worn vacuum lines with new silicone lines. Aside from these things, what other suggestions do you have?
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
