in tank fuel pump standard wire -
each 044 pump has own wiring apart from, wire from battery splices to each relay the rest is individual wiring from relays to pumps
wire roll says 3mm 10a
hope what i am describing makes sense
Edited by Reese69
  • Replies 48
The setup sounds fine, just need to make sure you are running the right gauge wire. Does it look like this:
3mm 10a wire:
Or like this:
8-gauge (round about 50a) wire:
That 8-gauge wire is the absolute minimum I would feel comfortable running from battery to relay for a single pump. If I was splicing that wire into relays for 3 pumps I'd be using 4-gauge wiring, which would admittedly be overkill but wire isn't such a great expense that I feel the need to be stingy about it.
10a wire is whats generally used...
8 gauge is way overkill... :woot: not to mention really thick and hard to hide around the car.. besides, how do u crimp and wire it to relays etc?
On a setup that can potentially see over 20a just in normal operating conditions, 10a wire is never going to cut it. Look at this:
These pumps draw 15.29 amps just at base fuel pressure. Hence why Resse69's 10a wire burnt out.
8-gauge is not that big, it's your general sound-system size wiring. Not that hard to get around the car, in fact when I had amps and my battery in my engine bay I had three 8GA cables all running the same route and they were invisible. You don't want your wiring to be the weak point of any electrical setup, but especially not in your fuel system.
As for wiring, that's easy. Use a horn relay with big terminals, and connectors to suit the wire size.
As mentioned, 8 gauge isn't hard at all to use. I can't remember exactly but pretty sure the wiring should be capable of double the intended load. Not to mention reese had burnt out 10a wire numerous times, how can you say it is ok?
Edited by superben
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
