I'm looking at selling my V35 in order to get a larger car more suited to a baby seat ;) Willing to negotiate but in no rush to sell so please no low ballers.
2003 Nissan Skyline V35 (350GT) Premium Model
- Luxury pack with Bose stereo, Premium black leather/suede interior/Iphone cable
- Aftermarket headlights
- Electric seats with memory function
- Traction control
- Brembo brakes all round with Project MU pads
- 6 speed manual
- 83,000 KM's - English and Japanese manuals included
- Optional extras including front lip, front and rear pods and boot spoiler
- BC BR coilovers height/damper adjustable (C-Spanners included)
- One off custom Forge wheels (Front: 20x10 -0 Rear: 20x11.5 -0) *Cost $4500 without tyres
- Professionally rolled guards all round
- Gloss black front grill with no badge
- Cat back exhaust with custom rear pipes
$26,500 ONO with Rego and Roadworthy.
The car turns heads everywhere it goes and being a newer looking car it does not attract the wrong kind of attention. Oil/filters have just been done and the car is VERY well taken care of.
Contact Matt - 0413120864 - Brisbane
W13662651581129323_1.jpg W13662651581129323_2.jpg W13662651581129323_3.jpg W13662651581129323_4.jpg W13662651581129323_5.jpg W13662651581129323_6.jpg
  • Replies 47
I can see why, looks awesome. Would you consider selling them and putting stock wheels back on? i spose it'd look a little silly with the coilovers and rolled fenders though lol
To be honest I would rather keep them on it because they really do make the car. Although if a buyer comes along that wants the car with stockos I will definitely let you know ;)
Oh man i didn't mean i'd buy them, i mean i'd love to but i can't afford it right now. I was just curious if you'd consider selling them separately to garauntee that $4500 or whatever you'd sell them for.
Haha no worries mate. To the other guys after them if I decide to sell the wheels separate I will post them up here but it's not very likely.
If only i could sell mine and buy yours, been really wanting a manual lately and yours seems a really clean example of a V35
The car is very tidy and needs to be seen in person to be appreciated! It will be going on Carsales this week if not sold. If you get rid of yours let me know, I will be happy to work out a good price for a SAU member ;)
