hey guys,
selling oil catch can setup to fund a new setup as I've moved onto a different vehicle. This setup works very well both on the street and the track and is can be used on the street legally.
2 x -10 lines from the rocker covers
1 x -10 line from the air intake pipe to the can
1 x -10 line from the oil filler cap to can
the catch can also has
1 x -8 that can be plumbed into the intake if wanted
1 x -6 that can also be plumbed into the intake
(lines and fitting are not included on this stuff)
Baffled internally and stuffed with steel wool.
I did not use either of the above lines because it wasn't needed can supply speedflow caps to block them off
It also have 1 x -12 drain to sump if you wish to have this setup as return. I didn't run this as the car didn't suffer from blow by and what did end up in the can wasn't enough to reach the level of the drain so only used it to clean the can out.
Location is Brisbane
Price is $550.00 maybe neg on price or could combined postage
(fair price considering each fitting is around $50.00 ea + hose)
https://www.sau.com.au/forums/topic/425531-ultimate-rb-oil-catch-can-setup/
