Item 1.
Genuine Rays Volk TE37 in White, 5 x 114.3
- 18 x 8,5 +30 fronts are in good condition
- 19 x 9.5 +35 rears are faded and 2 small dings in one of them, no cracks
- $1800ono
Item 2.
Genuine Exedy Clutch
- Genuine Exedy OE Replacement (Full Faced Organic) Clutch / Drive Plate (NSD098U)
- Unknown Cover!! I am told its off an R33, photo on Exedy wedsite matches RB25 diff cover
- Clearly you can see it has had minimal use
- $400!!!
This plate is found within the following Exedy clutch kits:
  • Exedy NSK-6531
  • Exedy NSK-6531HD
  • Exedy NSK-7056
  • Exedy NSK-7056HD
  • Exedy NSK-7297
  • Exedy NSK-7297HD
  • Exedy NSK-7377(SMF)
This Listing Suits The Following Application(s):
  • Nissan 180SX RPS13 (SR20DET, 01/1991 - 12/1998)
  • Nissan 200SX S14 ADM (SR20DET, 10/1994 - 03/2000)
  • Nissan 200SX S15 ADM (SR20DET, 01/2000 - 01/2002)
  • Nissan 300ZX Z31 200ZR (RB20DET, 10/1985 - 06/1989)
  • Nissan Cefiro LNA31 Attesa Cruising (4WD) (RB20DET, 08/1990 - 08/1994)
  • Nissan Cefiro R©A31 (RB20DET, 09/1988 - 08/1994)
  • Nissan Laurel R©C33 (RB20DET, 04/1989 - 01/1993)
  • Nissan Pulsar RNN14 GTI-R (SR20DET, 08/1990 - 01/1995)
  • Nissan Skyline HR31 JDM (RB20DET, 08/1985 - 05/1989)
  • Nissan Skyline HNR32 GTS-4 (RB20DET, 08/1989 - 08/1993)
  • Nissan Skyline H©R32 GTS-T (RB20DET, 05/1989 - 08/1993)
  • Nissan Skyline E©R33 GTS25-T (Series 2) (RB25DET, 01/1995 - 05/1998)
  • Nissan Skyline E©R33 GTS25-T (Series 1) (RB25DET, 08/1993 - 01/1995)
Item 3.
OMP Race Seat
- FIA Stamped
- Purchased from Revolution Racegear
- Comes with Revolution Racegear side mount brackets
- $400
Item 4.
Bride Drivers Seat Rail
- Super Low, Suits S13, S14, S15
- N045SL
- $80 (or $50 if purchased with seat)
Item 5.
Just Jap Seat and Passenger Rails
- Made for comfort
- Custom made passenger seat rails
- $150ono
Item 6.
HKS EVC 3 Boost Controller
- As Pictured
- $200
- All items are in Clayton, Victoria 3168
- I am willing to post, please PM me
- Discounts for buying multiple items
- Make an offer
- 0421 489 894
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
    • Absolutely matters because, while a temperature change will eventually reach a sensor at the end of a static line, the response time is far far far too slow to be useful. Might as well not have a temp gauge at all.
    • When I was eyeing off the 370GT (after deciding I didn't want to spend 30-40k+ to relive my early 20s in an R33) I thought it'd be a good project to add a turbo to it. Now that I have a 370GT, and I've had a couple of chances to open it up, I'm pretty stunned by how much power it makes 🫠 Honestly, the way the VVEL opens it up, it almost feels like there's a little turbo tucked away in there somewhere. It's like Nissan looked at VTEC and said "hold my beer" 😁 Has anyone thrown a turbo into their 370Z or 370GT? Is there a conservative boost level you can run without having to upgrade the fuel system, or are bigger injectors and a bigger pump a given?
