Hey there everyone. Although i own a Silvia (s13) I'm doing the age old RB25DET conversion on it for a Drift Pig. :P I came here purely for the knowledge that you all you guys possess about the sweet 25's. I plan on going above the 400KW mark, been reading through build threads all morning. I'll be running a 26 crank with rods, ect. any info / tips you guys have are much appreciated! As well as shops you guys use. I've got a few mates with Skylines and i guess you could say that Power FC limiter made me fall in love with the 25.
Cheers Andrew.
https://www.sau.com.au/forums/topic/428098-hey/
An S13 is pretty light, even an RB25 stock engine with bolt ons will give you a responsive 300-350kw which should be more than enough! No need to build an engine!
Spend the money wisely on bolt ons and maintanance and enjoy, but dont limiter bash an RB too long or bad things happen!
https://www.sau.com.au/forums/topic/428098-hey/#findComment-6916284
Keep cruising around and reading! When mine was making 350kw it was hard to get the power down to the ground through decent 265 tyres.... Now with 390ish it is going to be harder again! Keeping in mind my car is a few hundred kilos heavier than the S13! Get a stock engine with all the good bolt ons and screamer pipe (You said its a drift car) and you will impress your mates lolz
https://www.sau.com.au/forums/topic/428098-hey/#findComment-6916316
Yeah that is true, but traction isn't really a thing you need at the rears on a drift car. But still a valid point none the less.
To a degree it is i believe, you still want to be accelerating forward and have some form of grip.... Otherwise the run would just be a powerskid, different sport :P
https://www.sau.com.au/forums/topic/428098-hey/#findComment-6916468
Maybe in a year or two at winton? XD
Lol get back to me when you are ready!
For now, do your research on here! So much good info!
Have a look through my build thread in my sig to show what bolt ons can do to a stock motor!
https://www.sau.com.au/forums/topic/428098-hey/#findComment-6916506
welcome.
if you want something different, can I suggest a jag 6cyl?
but srsly, as mat has said above, bolt ons and maintenance for what youre going to do with the car.
have a read of his build thread, youll see whats achievable with bolt ons.
https://www.sau.com.au/forums/topic/428098-hey/#findComment-6917920
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
