For sale...
Nissan R33 GTR Skyline...
Rb26dett...
Manual...
125,000 k's...
R34 GTR intercooler...
Freshly repainted...
Aftermarket blow off vales (legal)...
Apexi Power FC...
Splitfire coilpacks...
Hks front coilovers (have rears but one is knocking so suit rebuild)....
Tien rear coilovers...
Adjustable rear camber arms...
Adjustable front castor rods...
Adjustable front camber arms...
Work xd9's 18x10 +18...
95% 265/35 all round...
Apexi intake pods...
RS Jasma Stainless front and dump pipes...
New front ball joints (all four)...
New iridium plugs & service done..
Kenwood DVD player..JL Audio amp
The car needs to be tuned only has a basic on the FC at the moment...
So runs a bit rich
Can come with a AM Preformance twin pipe full stainless with titanium tips exhaust (deletes cats & mufflers)
$22,500
0431 391 262 Luke
Pics up soon txt for pictures.
Car is on adelaide south australia
Edited by skyline_r33_panda
https://www.sau.com.au/forums/topic/428635-sa-nissan-r33-gtr/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
