hi all
I have a Brand New:
Apexi EL2 Boost Gauge Mechanical 60mm White Face For Sale: Resonable offers Considered... Goes up to 2.0Bar and has a -1.0 Vac Reading...
Apexi Silver Edition Pod Filter Brand New in box with intructions etc : Resonable offers Considered.... Largest Pod Filter Size you can get.... Bolts Str8 up to RB (turbo) Series and Z32 AFM... Dont Know About CA & SR AFMs...
Will Post Interstate at buyers Expense...
Reason For Sale: I Want A 180sx and My Rb20det R31 project never went ahead so they are sitting here in my room. Collecting Dust....
:D
https://www.sau.com.au/forums/topic/42961-brand-new-apexi-bits-2/
split the differance and make it $190 and you can have it.... im in Ringwood Area but can Drive Half Way to meet, depending on where you are...
Where Are you located??
$160 Shipped for the pod... You know the Black Versions of the Apexi Pod Filters?
its the same but its Full Chrome Metal and looks really nice...
no cod sorry...
i will try to find a pic of one....
:headspin: its all you need to bolt str8 up to the air flow meter... i have not seen this one for sale in australia b4... its up to u, doesnt bother me if you dont buy it or not ....
Mounting stand not a Cup. + a long vacuum hose and also jap instruction book(wiaring diagram is on www.apexi.com) and a little wiring loom that plugs into the back of the gauge and you wire into the indicattor switch so you get Light in the Gauge At night time driving.... Definately EL2....
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
