http://www.evolvedcoatings.com.au/liquid-wrap/
Seems like a cheaper alternative to Plastidip.
Apparantly they have a "clear" type of liquid wrap, sounds like it might be the goods for keeping my paint smick and preventing stone chips.
Anybody got any experiance with liquid wrapping there car?
I know lots of people do there wheels and they seem to out alright.
https://www.sau.com.au/forums/topic/434147-anybody-tried-ebc-liquid-wrap/
Used it. Wouldn't suggest unless you paint is absolutely perfect where you plan to use it. I had very small paint swirls on the nose of the hood and never really thought of it. Applied the stuff on. Got the car waxed and buffed. Now I got a super clean hood minus the nose of it. So.... get the paint perfect otherwise it looks funky.
Clear. Friend tried the "color matched" but once dried, looked horrible.
Hmmm
Can you describe what it looked like after you put it on?
Was it just like someone had put contact on your car?
Did it come off easy enough?
A friend at a Jaguar dealer helped is gonna help me with the next application on my new R33. I guess that's a common dealer option for their cars and he told me he'd help out to get it right. I guess if you really want it clean looking, get it professionally done. I know I'll never do it myself again. I've considered using a clear sticker thingy kit someone was talking bout but I'd think the clear vinyl would start to yellow from the sun.
Hmmm
Went on super clear. Looked like simple clear coat. Mask and tape off your area. Apply. Wait. Apply. Wet sand little. Unmask and wash. Wish I had a pic of it. Friends car was red. Stuff he got was supposedly color matched. Once dried, it looked deeper in color. Not sure if it was that he put on three apps or what. Couldn't tell at night but easy to see in the sun. Laid super flat and thin. He never tried removing it cause he later went to a fiberglass hood. I never attempted to take it off either. Far as I know, once it's on....it's on!
Hey TL.... I don't think you're talking about EBC Liquid Wrap? It's a Spray on Peel off coating, it's not distributed in the US and it's certainly not designed to be permanent.
With the clear, it comes in matte and glossy, so you will notice a difference between the finish of the coated area and non-coated areas.
My mistake. I was thinking of a completely different product. I didn't realize yours peeled off! I wish I had that years ago! Stuff I used was basically a clear coat paint system. Branch out man! We need that stuff here!!!! My fault for not fully researching your product. Thought he was referring to the kit I used.
  • 10 months later...
Its been about a year since this was asked...
Anyone tried it yet?
How does it compare to Plasti Dip?
Mainly interested in a wheel application.
999automotive had their own option at PowerCruise but cant remember what it is called
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
